Postby Fronterror on Sun Apr 14, 2019 7:34 pm
Changed lower ball joints and wheel bearings both sides, replaced dash lights and finally changed the rear shocks
Fronterror
Postby snapper on Sat Apr 20, 2019 9:55 pm
Finally got of me ***** to get on with sorting Truck out for a MOT next week....
That 'small' hole in the N/S sill under the rear door turned out to be close to 550mm long and ran from the wheel arch, ended up cutting everything away from the bottom sill seam to about 10mm down from the top. Then spent about an hour cutting, bending and fettling a new sill section to match the shape out of a piece of 1mm sheet steel from BnQ. That's now welded in place and awaits a few daps of filler and some paint in the morning.
Also found another hole, this time next to the front body mount. Also patched and awaiting paint.
Final spot of welding to do can wait for the morning, this time it's the O/S rear mount for the axle bump stop, spotted it earlier when doing the sill repair on the other side. It's not fully gone (yet) but I will sort it before MOT boy gets a chance to make comment.
Apart from that, a wire brush across all of the brake unions and rip out the old now redundant fuel lines (ran new ones in last year, just not removed the old ones yet), a quick service and it should be okay.....
I might, and it is might even give it a wash before taking it down!
Postby Fronterror on Sat Apr 27, 2019 1:40 pm
MOT passed for another year, advisories for corrosion to nearside chassis outrigger and rear bumpstops fully corroded
Fronterror
Postby enginseer on Mon May 27, 2019 7:46 pm
Fixed the cooling fans and made a new oil dipstick... Thanks to Fronterror I'm able to read the oil level :drink: :) also, new radiator... VM ready for the summer!
enginseer
Model: 2.5 TDS Sport 3dr
Modifications: bits and pieces...
Users browsing this forum: Google [Bot] and 3 guests
