Frontera Technical Support • View topic - lay out of the camp at sibbertoft
lay out of the camp at sibbertoft by andysd1 on Sun Feb 20, 2011 4:03 am
ok this is the what it looks like
and this is the lay out
the thick black line is a no-go area, this is the air field, (no playing in that zone what so ever)
the red circle is the camping area
the light blue circle is the toilets and showers, the small black line is the gate to them,
the yellow splodge,lol is the privet entrance in to the play area(just for us) do not use any other entrance to the play area,
the green line is where we propose the caravans set up as to block as much wind coming across the site, (thank you to all the caravaners)
the long red line, is a corporate route and is a no go area
the blue line is the one i am trying to get open, to save us using the car park, this may be open on the Friday, if so please use it,
the white one is the most important, this leads to the wood section,it can only be accessed by truck from the play area, there is a hill from the play area, as you go up the hill, you will see a gate, then the main road, and another gate, these gates are to be treated as if you where out on a lanning trip, closed at all time except for passing through them, you must NOT turn right or left on to the road from these gates, unless it is an emergency,
Re: lay out of the camp at sibbertoft by Fatbaz on Sun Feb 20, 2011 4:36 am
Hi All
Last time we did a weekend there we came in and out the blue line. Last time we were there for the day we use the red line to just after the cark (grey blob area to the right of the Off Road site) then entered the site by a gate there. As the red line procedes passed the gate we used there is a sign that says "NO MUDDY TRUCKS BEYOND THIS POINT". Expect this still applies, it's to stop the mud from being splattered all along the nice track the cars (carrying hovercraft and clay pigeon punters) use, wouldn't do to get the company car muddy.
Laters
Stuart :D
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: lay out of the camp at sibbertoft by andysd1 on Sun Feb 20, 2011 1:05 pm
he said there was a problem with the blue route, but will sort it out, so look out for the sign, plus i dont think caravans will go down the red route
Re: lay out of the camp at sibbertoft by Fatbaz on Thu Feb 24, 2011 4:36 am
Caravans going down the red route might end up with bits missing off the top!!!!!!!!!!!
Fatbaz
50mm body lift
Re: lay out of the camp at sibbertoft by hipo1024 on Tue Mar 01, 2011 1:01 am
Re: lay out of the camp at sibbertoft by andysd1 on Tue Mar 01, 2011 1:53 am
the blue route will be open, and he does not want any muddy trucks going up and down the red route, as he gets a lot of companies having days out on the other parts of the adventure club, so he dose not want the bmws and mercs getting covered in mud, or having them driving along a mud track, as its covered with a fine gravel stone,
so to all, do not use the red route,
Re: lay out of the camp at sibbertoft by andysd1 on Tue Mar 01, 2011 1:55 am
but to answer your question hipo, he does not want any one on the red route, and no one should be using it,
Re: lay out of the camp at sibbertoft by andysd1 on Tue Mar 01, 2011 2:09 am
update
Re: lay out of the camp at sibbertoft by hipo1024 on Tue Mar 01, 2011 2:24 am
oh ok, that makes sence! :)
