Help:Starting a new page
From FogWiki
Jump to: navigation, search
PD
Important note: When you edit this page, you agree to release your contribution into the public domain. If you don't want this or can't do this because of license restrictions, please don't edit. This page is one of the Public Domain Help Pages, which can be freely copied into fresh wiki installations and/or distributed with MediaWiki software; see Help:Contents for an overview of all pages.
There are several ways to start a new page.
Contents
Using Wikilinks
MediaWiki makes it very easy to link wiki pages using a standard syntax (see Links). If you (or anyone else) creates a link to an article that doesn't exist yet, the link will be coloured red, like this.
Clicking a red link, will take you to the edit page for the new article. Simply type your text, click save and the new page will be created.
Once the page has been created, the link will change from red to blue (purple for pages you've visited) indicating that the article now exists.
Usually this is the best way to create a new page, because it means that right from the start, the page will be linked from at least one other place on the wiki (and typically you will want to mesh it into other related pages later) If you are creating a new page without creating any link to it, you may need to ask yourself: Does this page really fit in with the topics already covered in the wiki? Also, how are you expecting visitors to find this page? Normally there is no reason to create a page without first creating a red link to it.
Using the URL
You can use the wiki's URL for creating a new page. The URL to an article of the wiki is usually something like this:
  • http://www.example.net/index.php/ARTICLE    or
  • http://www.example.net/wiki/ARTICLE
If you replace ARTICLE with the name of the page you wish to create, you will be taken to a blank page which indicates that no article of that name exists yet. Clicking the "edit" page tab at the top of the page will take you to the edit page for that article, where you can create the new page by typing your text, and clicking submit.
From the search page
If you search for a page that doesn't exist (using the search box and 'go' button on the left of the page) then you will be provided with a link to create the new page. (Note that this technique doesn't work if you use the 'search' button).
Image:Tools.svg Tip for wiki admins: The "inputbox extension" allows you to provide an even easier way for your users to create new pages
Create redirects to your new page
Don't forget to setup redirects when you create a page. If you think another person may search for the page you've created by using a different name or spelling, please create the proper redirect(s). See Help:Redirects
Protecting your new page
Normally a new wiki page can be edited by other people (that is one of the main ideas of a wiki!) However, you could 'protect' the page, if desired, to prevent normal users from editing it. This requires sysop permissions.
Personal tools
Support
