B series dashboard fault
From FogWiki
Jump to: navigation, search
Frontera B Series dashboard fault fix
Contents
Fault
Speedo, Rev counter and fuel guage don't come on with the ignition, but will show when sidelights turned on
Applies to
All B series Fronteras
Required equipment
  • Screwdriver
  • Low wattage soldering iron
Difficulty Level
Medium
Estimated time to complete
1-2 hours
Fix
  • Take out the 4 screws that hold in the facia - 2 by the speedo cocks on the underside of the dash, and 1 either side of the steering wheel behind the lower trim
  • Once the facia is off the speedo cluster is held in by 4 screws you can then pull the speedo out a bit so you can disconnect the 3 cables
  • Once you have the unit out you can remove the black panel that surrounds the speedo which also holds the perpex cover
  • Then its onto the needles at first it seems the little buggers dont want to come off but a bit of prising with my fingers and a bit of and they came off luckily without taking the pins with them
  • Now you can peel off the speedo black cover
  • Remove the clear plastic cover (this just pops off)
  • Now prise the board out by pushing back the little clips and there was 1 torx screw to take out. Also if you turn the thing over you will see in the corner a little square that a bit of the membrane goes into and there are a couple of bits of metal to bend back and now the board will pop out
  • Using a low wattage soldering iron, check and retin connections on the board, particularly the ten connectors where the wiring loom attaches - Be careful!
  • Reassemble the dash unit and refit
Submitted by
  • Unknown
Forum link(s)
Personal tools
Support
